I have a problem with contact analysis.
My model is working fine in one direction (let's forget about the connection between the bearing and the gearbox), i.e. the bearing pushes away the flange. However, if I change the direction of the force, in which case the bearing should slip out and has no effect on anything, the bearing still pulls the flange. What do I have to modify to make the bearing available to push the flange but not pull?
Thank you
aecyd
