Hello guys!
This is my first time dealing with HyperMesh and Finite Element software, and Im kinda having a hard time using it. I'll be glad if any of you guys can help me out!
Im building a Formula SAE Chassis and I need to check if there're any extra bars and also check if any of them will break and so on.
I already learned how to do meshing on each bar, but now I dont know how to apply loads and start the 1D linear analisys for the beginning.
I also found a Tutorial here but I do not have the samples to start the workshop...
So...after having the chassis imported from solidworks and have all bars meshed, where should I start now?
Thanks a lot!!
PS: Already solved the problem with importing (from another topic).
