Hi to All,
Can anyone tell me who to set meshing parameters in order to two part sharing the same nodes at there junction?
Please see the attached file as an example of non corresponding meshes at a T tube junction.
Thank you.
Hi Malick,
I think you can try 2D >> Mesh edit >> extend panel. It may be useful for this kind of issue. (see attached picture)
Hope it helps.
Regards.
If you have surfaces for Both the components,,..
Just do the surface edit(shift+F9) by selecting both the surfaces, If not use the extension option in the same menu.
It will give you a T-edge in between, that will make you comfortable to edit the mesh parameters at that location,,..
If surfaces are not there I support Newbie's is the best option,,..
Hi Malick, I think you can try 2D >> Mesh edit >> extend panel. It may be useful for this kind of issue. (see attached picture) Hope it helps. Regards.
Hi NSKRTLUS,
Thank you so much for your help and for the picture. This was the real thing I needed.
Sorry for my late response, I disconnected for few days.
Have a nice day.
Hi Malick, If you have surfaces for Both the components,,.. Just do the surface edit(shift+F9) by selecting both the surfaces, If not use the extension option in the same menu. It will give you a T-edge in between, that will make you comfortable to edit the mesh parameters at that location,,.. If surfaces are not there I support Newbie's is the best option,,..
Hi Raviteja,
Thank you so much for your response. It is very nice to see people available for help.
Sorry for my late response since I was disconnected for few days.
