To mesh an ellipsoid
Altair Forum User
Altair Forum User
I created an ellipsoid and it comes under multibodies without surface.
I need to consider this ellipsoid as an ball and i need to do both the surface and volume mesh for the ellipsoid.
How could i do the suraface and volume mesh for the ellipsoid ?
There is no dpecific properties for the ellipsoid, i just need to mesh it
Thanks in advance.
  • Altair Forum User
    Altair Forum User
    edited August 2017
    Hi Sindhu,
    I am a little confused, what do you mean without surface?
    If you can extract surfaces from mating parts you can use automesh panel to create a random surface mesh. If you need more structured mesh, you can split the surface and mesh the same.
  • Altair Forum User
    Altair Forum User
    edited November 2020
    Hi Prakash,
    Thanks for your reply. And also Sorry for the confusion. I am new to hypermesh. So i could not explain properly.
    I have attached the ellipsoid file. I need to mesh(both surface and volume mesh) this ellipsoid. What is the best possible way to mesh it with good quality ?
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited August 2017
    How you got your ellipsoid? I can't extract surface from it.
    So try to create/import an ellipsoid to mesh. See my screenshot:
  • Altair Forum User
    Altair Forum User
    edited August 2017
    Thanks for your information.
    I got my ellipsoid from Tools-- Build menu.
    And i am new to hypermesh. So, i like to know how to create /import an ellipsoid to mesh ?
  • Altair Forum User
    Altair Forum User
    Hi Sindhu,
    Here is a meshed file.
    I used a macro which I cannot share for now... Sorry about that :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    edited August 2017
    The file which you sent is not compatible in my version of hyperworks.:mellow:/emoticons/default_mellow.png' title=':mellow:' />
  • Altair Forum User
    Altair Forum User
  • Altair Forum User
    Altair Forum User
    edited August 2017
    Thank you for the file..:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> It worked
