Point Mass Addition
When I use the admas Option in 1D, it gets created also it creates a set. If I delete the set is the admas deleted. Where can I visually see after the admas is kept.
In the model attached, the admas is added on the top most node in the column, Set number is grnodeAdmas 22.
Now, I could not find where is the input value of the mass of 60Kg that I have added in it. I wish to change it and deletion of the set gives me an error.
yours sincerely,
kartik
Altair Forum User said:
yours sincerely,
kartik
Also kindly explain how to remove the added point mass completely. Using delete option only deletes the node set
0 -
Thank you
