Having transparent elements with a dot at its center and also having surface meshing instead of a tetra 3D mesh
Can anyone solve the issue?
Try this:
Make sure geometry is enclosed before using the volume tetra option.
Hello Sir
Geometry is enclosed one but the thing happening with me is very unusual.
The elements created during meshing is not the one which always created during proper meshing, actually they don't have any color they are transparent having a center dot with them.
This problem not only occur with my software edition but also with my friends.
Tell a solution for this.
Can you turn on shaded elements and mesh lines as @Q.Nguyen-Dai suggested?
It would be better if you zoom a little bit and post the picture of the same
