Can someone please explain me the concept of breakangle? (Found in Edge Edit and some other tabs)
PFA, from help
Thank You!
Can you please explain how is it useful over in the Suppress option
Hi Vaman,
if the break angle between the normals of adjacent surface edges exceeds the set value, the edges will not be suppressed.
