i have connected two parts by rigid elements (calculated nodes). now i want to convert this rigids into Beam elements. but after converting beam elements should be as it is like rigids.
can any one help me.
Sandeep
Hi Sandeep,
I am sorry, I did not understand what your requirement is, Can you explain in a little detail, please?
ok. sure
please see below image. in 1st image putted rigid elemets to hole. want to convert this rigids into Beam elements. you can refer 2nd image.
is there any method to create multi Beam elements like rigids (Spider)?
sandeep
Sandeep,
I don't see a direct option to do convert a rigid spider to Beam in HyperMesh.
You need to do it manually.
FYI,
There is a script on Script Exchange for the same...
Hello prakash,
it is more time consuming process to create manually. the way should be there.
can you help more regarding this query. you can take your time.
Thanks & regards,
Here is the link to the script and there is a video demo on the same..
https://connect.altair.com/CP/kb-view.html?kb=100069
You need to create an account to access script
how i can get this script?
Here is the link to the script and there is a video demo on the same.. https://connect.altair.com/CP/kb-view.html?kb=100069 You need to create an account to access script
ok sir
Hello Prakash,
I did it. i am very much happy that you provided me solution.
Altair forum is great! Thankful from the bottom of Heart.
Best Regards,
Sandeep Pardeshi
