Hi all,
Sometimes I can't visualize the temporary nodes created. The nodes are there since I can clearly see their numbers (see picture attached).
How can I solve this issue?
Thanks and regards.
Can you please delete your settings file and try again.
Thankyou
Version of your installation Hypermesh?
How about your graphic card?
Thank you guys, deleting the settings worked!
Had the same issue. Updating the graphics driver fixed this issue.
