Optistruct - No results / Succesfull Completed Job
Altair Forum User
Hi RubenP,
Do you see .h3d file in the working directory?
Can you share the .out and .stat files for the analysis?
delete setting files on your machine and try again. Follow the link below on how to delete setting files:
http://forum.altairhyperworks.com/index.php?/topic/13434-how-to-delete-settings-files/?hl=delete
Also, delete .Altair folder in temporary directory. Go to Run and type in %Temp% and click OK
0 -
I tried to solve another analysis, which worked out. Then i did an other attempt on the other part, which suddenly worked out again.
Thanks for the help
