Good morning
I'm having some issues with winprop, I followed the steps in the video below but when I tried to look the results a message appears, I don't know what is going on.
https://altairuniversity.com/learning-library/propagacion-de-senal-wifi-en-winprop/
in case the transmitter was modified the results become invalid and need to be re-computed.
Please press the RunPRO button for re-computation and in case of a network planning project then also the RunNET button for computation of the network planning results.
Hi is this available also in English?
it doesn't work for me. nothing happens when I pressed Runpro. Then when I clicked the Power hoping to see the result, it has that message. I do not know what is going on and was stuck here for a day..
hello , even I am facing the same problem as mentioned above , could someone help us solving this issue.
I too have the same problem as mentioned above could anyone of you please help me?
Hi there. I too have this issue. Somebody can help me, please?
Hello, in case the transmitter was modified the results become invalid and need to be re-computed. Please press the RunPRO button for re-computation and in case of a network planning project then also the RunNET button for computation of the network planning results.
Hello. I'm using the student license, and the re-computation doesn't work for me. Every time the system show me this error. Please, help me.
Here is my project. /emoticons/default_wacko.png' title=':wacko:' />
