What is 2D and 3D mass? There is an option to select such mass in HyperMesh for the preferene of Ansys under ET Types.
These options are available under 1D category of HyperMesh which are used for lumped masses. If Mass node is known as a zero dimension element, why do we have these options and where can it be used is what I want to understand. Thanks in advance.
