Hello group
what does this card from Control Card image indicates
I especially want to know what is FL
and how does it effect results.
Regards
Pratik
(your thumbnail seems to be empty.) corrected ;-)
Normally FL means First - Last.
If you have a iterative solution process, then only the first and last iteration is written to the output file.
If i remember you can change it to FL, FIRST, LAST, ALL, NONE and N=
Best Regards,
Mario
Hi Pratik,
This will be useful to check the results of different optimization iterations for design considerations.
