Getting this error (screenshot attached) while working on a model on HyperMesh. How to resolve it? Please help.
could you let us know when do you get this error?
Are you trying to run any .tcl file?
can you try the below:
Close HyperWorks application(s) and Please delete setting files on your machine. Follow the link below on how to delete setting files:
http://forum.altairh...iles/?hl=delete
Also, delete .Altair folder in temporary directory. Go to Run and type in %Temp% and click OK.
now try again to check if you still get this error.
Prakash,
Thanks for your valuable suggestion. I have re-installed HyperMesh and the issue is resolved now.
If it happens on future I would definitely try out your suggestion.
