hello
how to mesh this spring with HyperMesh : http://cjoint.com/?EDbnlnvVzVI<?xml version="1.0" encoding="UTF-8"?>
thanks
best regards
See my attached files. HM model is v12.
One way I would think is mesh on one of rhe vertical faces of the spring and drag the 2D elements along the lines of the spring to create a 3D mesh.
Ok thanks
i used trim with bounding lines to split the spring and mesh it one by one with solidmap
thanks again
http://www.cjoint.com/15av/EDclhQNxrzg.htm
@FILY: Are you sure about mesh density? Don't forget that the quality of analysis depend to the quality of your mesh.
True no @Q.NGUYEN-DAI , so i will verificate if i do a simulation under Radioss
