MotionView Constant radius error. Constant radius circling Report-arg6
Hello all,
I need some help to solve the next issue in a 'constant radius test' in MotionView.
Someone knows how to solve this error?
Thanks in advance!
Checking references and data in System Model
Checking references and data in System Misc
Checking references and data in System Body
Checking references and data in System Rear subframe
Checking references and data in System Rear linked solidaxle susp
Checking references and data in System Rear shock absorber ( with inline jts )
Checking references and data in System Rear coil spring
Checking references and data in System Rear internal jounce bumpers
Checking references and data in System Rear internal reb bumpers
Checking references and data in System Frnt subframe
Checking references and data in System Rackpin steering
Checking references and data in System Steering column 1 (not for abaqus)
Checking references and data in System Frnt multilink susp
Checking references and data in System Frnt shock absorber ( with inline jts )
Checking references and data in System Frnt coil spring
Checking references and data in System Frnt internal jounce bumpers
Checking references and data in System Frnt internal reb bumpers
Checking references and data in System Live axle
Checking references and data in System FIALA / HTIRE
Checking references and data in System Constant radius analysis
1 Error: Unknown symbol MODEL.sys_tires.o_ms_cp_forces_sae_right_rear.id
Error resolving entity Constant radius circling Report-arg6 under
Model-Constant radius analysis.
Checking references and data in System Output Requests
Checking references and data in System Steer controller
Checking references and data in System Drive torque controller
Finished Checking Model
Errors were detected in the model.
HI,
Looks like you referenced symbol MODEL.sys_tires.o_ms_cp_forces_sae_right_rear.id and it no more exits or not realized.
Can you share the model file to check for the errors?
