How to fill Load Collector INIVEL AXIS card ?
Hi !
I'm currently working on a blade shedding problem at school. I'd like to impose a rotational velocity to a blade but I don't know how to fill correctly the INIVEL/AXIS card. Does anyone know how to do it ?
The blade (in green) is supposed to turn around the grey cylinder axis.
card definition has changed from Version 11 to Version 12. But with the new definition, /INIVEL/AXIS works well in version 120 and 130.Hence try in latest version.
See attached screenshot.
Regards
Thanks for your response.
We don't have access to the latest version in our school. So our only option is to fill the card we've sent you. The trouble is we don't know what the differents boxes stand for.
Regards
COMBES Félix
hi rahul, please have a look, its taken from 13.0 version for the INIVEL/AXIS entity editor. Which one is correct?.
regards,
ashok.
Above one is from Tools BC manager & you can try from create card : BC. See attached screenshot.
Which version of Hyperworks you are using?
Regards
Rahul R
