I'm desperately trying to calculate a modell with spot weld but every time, i get the following error-msg:
Ratio of weld diameter to average shell/patch size (D/L= 29.3) is larger than
the limit value of 10.0.
CWELD element id = 123
Well, the diameter of the spot weld is 3mm and the size of the attached elements is 0.4mm. The length of the weld-element is 1.2mm. So, everything is below the allowable limitation, therefor, i have no idea how to solve this. Thank you in advance for your answer(s).
Regards
