HI FEKO Expert,
   I would like to ask FEKO team about the warning that I received when I running the near field request. I am doing dipole antenna using wire port. What does the warning means so that I can make
   inprovement on my model to achieve the results. I have attached the warning image with this email. Hope to hear from you soon to help me encounter this problem.
   below are my warning details:
   Warning 81: singular field on the axis of a segment
   Warning 2340: No further output of warnings and hints
   Thank you.
