Hi guys,
I modified the criteria file editor such aspect ratio, warpage,... for 'QI optimize' meshing. But now I would want restore the previous values, how can I make it?
If you have saved criteria editor file then you can recall that file or you would get general criteria file from installation location.
C:\Program Files\Altair\14.0\hm\batchmesh
If the previous criteria was set by you, try searching for *createdoublearray 89 and *reset_qa_calculator in command.cmf file
then rerun those commands
