I'm a student. I have a problem with Hypermesh so I'd like to ask somebody...
I must model a structure made of two components, both with a small thickness, in contact with each other.
I would like to use shell elements to model each of the component... so, after importing the CAD geometry, I have extracted the relative midsurfaces. The problem is, in this way the thickness of both components disappeared, leaving a gap between the two parallel midsurfaces... For this reason, I don't know how to 'tell' the program that there is contact between the two components (and consequentially some forces transmission)... How can i solve this problem?
Thank you anyway
Desperate student
