Hello everybody,
The aim of my master thesis work is to execute the elasto-kinematic analisys of a mini-car.
I was supplied with text files containing informations on the geometry of the anterior and posterior axles, (coordinates, inertia moments), steering wheel and the characteristic curves of the primary and secondary elastic- organs (springs and bushings) and dampers. I began modeling the suspension of the anterior axle, starting from the pre-imposed model given in Motionview through the procedure Model—>Assembly Wizard, and substituting the text files data I was feed with where they supposed to be in the pre-imposed model.
I ask you the following questions:
- How can I substitute a single system (intended as a part of a model, for example just the steering part) having it on another file?
- How can I add other components on the default model (for example I realized that I’ve got to add bump-stops and rebound-stops) , without having to re-do everything?
- Finally, how can I assemble anterior axle with posterior axle after having done, separately, one and the other?
Thanks, whoever will answere.
