Hi.
I have Two cuboid blocks of different materials, one inside another. i.e. Outer block has a cuboid space at the center in which inner block is placed. See Here. http://i.imgur.com/zGuGj.png The outer surface of the inner block is in direct contact with the inner surface of outer block.
A very high value constant heat flux(Burned in a furnace ) is applied at the outer surface of the outer block.
Now I want to see the thermal and structural behavior of both the blocks.
How should I proceed? What are the interfaces that I need to give for the same. I have gone through tutorial RD 1080. but it didn't work.
