I'm trying to analyze Spur Gear Contact Problem.
however,
I don't know how can i construct constraint which fix position allowing rotating of axis of gear or gear bore.. kind of Frictionless Support.)
(I'm using Optistruct)
Please try with Optistruct contact card.
Regards
Rahul R
Which contact type is required for frictionless contact in optistruct ?
Hi ANK,
You can use SLIDE contact without specifying friction.
