Hello All,
How do we represent the shock absorber in the suspension system , Please suggest.
Regards ,
Bhuvan
Hi Bhuvan,
Which solver you are using?
For OptiStruct, you can model suspension using CELAS element (spring element) and can assign with PELAS or PBUSH property.
For RADIOSS, you can model suspension system with Type 4 or Type 13 spring property.
SIR
what is dof1 ,dof2,dof3. . . . . . signifies here
and what is the significance of orientation vector and how to initialize it
please reply me
Hi akash@1995,
Dof1, 2, & 3 are translation degrees of freedom in x, y, z direction respectively. Similarly dof4 , 5 & 6 are rotational degrees of freedom in x, y , z direction respectively.
If dof2 is selected, it means that you are constraining translation movement in the y direction.
Orientation determines how springs are oriented in 3D space. Click the switch and select from either node, vector, and components.
Components: To be used if the direction of the local y axis of the spring is to be specified by typing in the X, Y, and Z components.
Thank you
