Hello all,
For stress analysis, I want to show the stress value of some nodes, in order to make a screenshot for documentation. To do this I put a note on the selected node, and in the note i write {entity.contour_val}. Now the problem is, that i get the value of the selected node and all of the nodes surrounding it. But i only want the stress value of that particular node. Does anyone know what to do? Thank you in advance.
Hi Fadi,
I think this video will help you.
Thank you
