Hello, is it possible to volume mesh two surface mesh that are not enclosed?
Thanks
Yes, you can make 'linear solid' between 2 surface mesh. In this case, two surface mesh should be 'similary': same nodes, same elements, same topology,....
thanks. How about the alignment option, it's a bit confusin...I was expecting it to ask if we choose x-xis or z axis
See attached screenshot.
Regards
Rahul R
