How to specify static displacements on set of nodes(non zero)?
Hi...Everyone.....
I have to do linear static analysis. I want to do specify static displacement on set of nodes, i have used DAREA to specify the same. But i am getting unreasonable results. Is there any other way to specify the static displacement on the node?.
Thanks in advance /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Ramsubramanian
Hi Ramsubu93,
Try with SPCD instead and check whether you get expected results or not.
0 -
Thanks sir.........
But in Linear static loadstep, where to refer the SPCD?
Can i refer SPCD in DEFORM?
0 -
First you will need to create a SPCD on the required nodes, this will be in a load collector.
Then you need to create a SPC load collector and constrain the DOFs specified in SPCD in this SPC collector,
Then Reference SPCD load collector in LOAD , and SPCs in SPC section of the loadcase.
0 -
Thanks a lot sir.......
