Hello, could you please help me with a macro that I'm creating?
I just create a node with the command '*createcenternode 8000078 8000024 8000049', I want to select the node by the ID, but I don't know how can I do that since the ID will change every time I create it.
I tried to put the id in a variable 'set ta [*createcenternode 8000078 8000024 8000049]' but didn't work.
I hope that you can help me. thanks in advance.
