I want to generate SAR values similar to seen in this link (https://www.feko.info/applications/white-papers/thermal-analysis-for-implant-safety/implant-sar-distribution) in my design. I am wondering which options in the SAR request window should I select?, I tried all options available but failed.
Thanks in Advanced
Hi csbk
This image appears to show a Near field result. If you request a near field cut through a lossy dielectric, SAR will be available under the Quantities for the near field result.
Johan H
Thanks
