I am seeing an error in a couple of files where the displacement contours are plotted 'backwards' on the model.
That is, the displacement contours are plotted at full magnitude on the undeformed model at t=0
Then at t=1, all contours show zero magnitude but the model is in it's deformed state.
Von Mises Stress contours appear correctly, with 0 stress at t=0.
RADIOSS solver deck. Results from other parts using the same deck are displaying as expected.
Thanks
