During springback analysis .rad files are not generated. So, what corrective actions should i take?
Please let me know if you are running the solver through command window. If so have you tried running the job in Radioss manager.
Regards
Rahul R
Sir, actually I followed the procedure of tutorial springback hf-3040.
Also, I have obtained the required files (bent.hf and bent.hmx) for springback through forming simulation but, I felt problem in include file option i.e when i open the file bent.hf then bent.hmx file will not be loading.
Sir, please reply me as soon as you can.
Thank you
