hi , guys is it possible to covert solid model to surface model in hyper-mesh. if anyone knows pls help me out
Rakesh,
Do you mean solid mesh to surface mesh?
No prakash.. i want solid model to be converted as surface model.
Regards
Rakesh
Go to delete Entities panel (F2 is the shortcut), Change the entity selector to solid and delete the solid. But make sure 'Delete bounding surfaces' option is uncheked as shown in the image below:
Thank you prakash .
rakesh patil
