Submitted by Joe on Tue, 04/24/2012 - 18:49
With respect to the Motion BLDC block: Is 'Rotor shaft Coulomb Friction Magnitude' equal to 'Hysteresis Drag Torque'? The spec sheet has a value called 'Hysteresis Drag Torque' that has the same units (Nm) as Rotor shaft coulomb friction.
