Submitted by yue on Fri, 08/01/2014 - 08:40
I have acquired the TI DRV8301 kit from Texas Instrument. The INSTASPIN seems to be close sourced in how it estimates flux, angle speed and torque, therefore I'm thinking of using Vsim instead for implementing the control. My question is that is it possible to use Vsim to implement the following control schemes on a brushless dc motor with trapezoidal shaped back emf:
- six step commutation which injects 120 degrees square wave current
- vector control (similar to that employed for permanent magnet synchronous motor)
If so, and if it's true that VisSim supports drv8301 kit, where can I find the relevant application note/ source code/ example for this?
Thanks in advance.
Yue Yao
