Good morning
I have a discretized model as in the attached figure, how can I export the geometry of the upper surface? Can you explain it step by step?
Thanks in advance for your assistance
what is the extension of shared file?
the shared file is a picture of the model, the extension is TIFF
Is upper region geometry is planar?For solid elements you can extract 2d faces then generate surface from elements.If desired surface is planar then one can make use of Ruled spline skin command of 2d page for surface creation.
the top surface is not Planar, it has errors form
could you share meshed file?
yes i could
https://ftin.india.altair.com:8443/message/KRD1II5jZhCKByR9IS3Cin
video in mp4 format.please unzip it first.
Thank you so much for the quick reply but the browser cannot open the link
Its a FTP link.Click on attached file to download.
I can't open the link that you have posted
PFA.
Thank you so much for your assistance.
