I know someone has asked this topic before. However, all the solution I found did not work on my case.
I used 'edges' to find the free edges between two hex elements. I have tried to remove it by ' equivalence ' and by deleting the elements and creating them again. When I checked the nodes on the two hex elements. I found that there is one shared node has two ID numbers. So I also tried to replace one ID with another ID. None all these methods worked.
Please help me.
Thank you very much!
