Submitted by djobrien51 on Fri, 06/17/2011 - 19:48
In the Embedded Controls Developer Users Guide v8.0 (EmbeddedControlsDeveloper_UGv80.pdf) under the section 'Using the VisSim Code Composer Studio Plug-In' a procedure is described to '...create a [CCS] project that contains all the necessary files (.CMD, .LIB, and generated .C file from VisSim) to successfully build an .OUT file from the code composer environment.'
The menu item to select in CCS v4, 'Tools>VisSim>Create VisSim Project' doesn't exist in my CCS [Eclipse] installation.
Apparently, even though I installed CCS v4 first and then VisSim 8.0, the required CCS [Eclipse] plug-in never got installed.
Is there a way to post install plug-in, and why didn't it get installed correctly?
