Is there a way I can get the Tsai-wu failure criteria index for a Divinycell (Poliurethane foam) material analisys ? I am using MAT8 and P-shell property card. Thank you!
I used 'Derived results' to build Tsai-Hill criteria:
And define expression with 'Expression builder':
Maybe you can do the same with Tsai-Wu?
