I am going to do a crash simulation with a non-deformable wall crashing a tube at a constant displacement deformation through Ls-Dyna solver. (please see the pic attached) The tube is going to be meshed with shell element using the mid-surface. The tube is constrained with 6 dof at the bottom.
What I know is if the wall is going to be meshed with solid element, it will show deformation from the simulation result. So how can I create a wall without any deformation but perform the constant displacement crash simulation?
Many thanks.
