In the figure attached you will notice that there is a suspension like a spring that allows to absorb the forces created by the rail, so how can i say to Hypermesh that this solid is a spring with a certain rigidity.????
You can use spring or bush elements to model the phenomena
refer to CELAS / CBUSH in optistruct reference guide
