I see the following error:
Error 3848: Wrong specification of a medium for a wire segment.
What does it mean and what should I do to fix it?
This error can occur if a wire segment is inside a dielectric but not Unioned with the rest of the model.
It could also occur when a mesh of wire segments is imported and positioned inside a dielectric. In this case the proper medium settings must be set in the details tree in CADFEKO for the wire segments.
