Respected sir
I am working on a mechanism for creating JOINTS. I need exact center of the geometry and there are many joints in my geometry. so how to create accurate point can I import pints?
Hello Vishal,
In MotionView there is option called points (Create points and give value of coordinate axis as shown in figure )
Now that value of points you can get it from your CAD or Drawings
There is another way
Open your geometry in HyperMesh (during importing take care of Units)
Create Points for your joints location in HpyerMesh and Save Location of your points and use that value in MotionView
(Hypermesh: Geometry>Nodes>XYZ>> Click on nodes and you will get coordinate location value)
