I got a few issues using Inspire 9.0:
I m designing a single Solidworks part - produced out of a mold with a dedicated wall thickness.
The outside freeform surface cant be modified and is fix.
I m searching for a optimized rib structure and thickness on the inside surface.
Is there any way you would suggest to solve that problem?
thanks and all the best
peter
