how to implement while and for loop using embed blocks? Can anybody help me out.
Hi Nit,
I'm attaching an example model that shows you one approach to creating a 'For' loop and a 'While' loop using Embed compound blocks.
Ric
Thanks Ric for an early response
Is it possible to implement delayus() a C library function In Embed through block diagram? . If yes then how to do it?
Any other way of implementing delay in block diagram?
Here is a simple Embed diagram of one possibility that should demonstrate the timedelay block. In this case i added a 5 second but could be any other as well.
There are also other ways for instance :
1) You could rely on the runcount and setup the step time of a diagram .
2) Use a statechart and do a software counter and trigger right events from a state chart .
Hope this helps !
--sreeram
