VisSim error message "TI driver error -1047, PTI_ERR_EMU_CLOSE"
Altair Forum User
Altair Forum User
Submitted by C2000 user on Sat, 03/12/2011 - 02:12
I'm using VisSim with a F280x eZdsp emulator connected to an F2808. The emulator is working fine with CCSv4. When I try to run the example 'exemple f2808-d' model I get the following error message: 'TI driver error -4037 . Any ideas please? Thanks in advance!
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by Anders89 on Mon, 03/14/2011 - 07:07.
    You must select the Blackhawk emulator in the target configuration dialog. If you are running vissim 7, then the config dialog is found under menu item:
    VisSim/DSP > F280x > DSP Config...
    If you are running VisSim 8:
    Embedded > F280x > MCU Config...
    Then choose Blackhawk under JTAG Connection. The diagram you mention defaults to USB XDS100, so you must change this to avoid an error message.
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by C2000 user on Wed, 03/16/2011 - 01:50.
    Thanks, but I had already selected 'Blackhawk USB2000' in the MCU Config window. The error message is the same.
  • Altair Forum User
    Altair Forum User
    edited November 2020
    Submitted by Anders89 on Fri, 03/18/2011 - 03:15.
    Richard, It turns out that the BH-USB2000 interface changed recently. This required a change to a support file. It has been updated in the VisSim ECD install, but you can download the attached .dat file (you must be logged in to see it) and copy it to your \vissim80\cg\lib\brdDat directory instead if you like.
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by C2000 user on Sat, 03/19/2011 - 00:57.
    That's great. It works fine now - thanks very much for your help.
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by dlarco on Mon, 07/30/2012 - 15:58.
    Hello I have a eZdspTMS320F2812 card with socket when I tray to connect there are the followin error
    With VisSim 7 Target read MBOX_IN failed Download failed: Check config for correct target number
    with VisSim 8 TI driver error -1142 PTI_ERR_QUAL With eZdspTMS320F2812 card without socket, there are not any problem Best regards , thanks in advance Damian
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by Anders89 on Mon, 07/30/2012 - 19:23.
    Damian,
    Sorry to say, but if it works fine on one board but not on the other, then likely the board is bad. Can you try a new CPU in the socket? You can get new CPUs from TI for free by ordering samples from their web site.
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by rajinmlinus on Sun, 09/22/2013 - 15:54.
    Dear Sir/ Madam
    I am using eZdspTMS320F2812. I will download the program through JTAG PP emulator and using Vsim7. While i start to run i am getting the error of TI Driver Error-100?. Can you anyone please help me to rectify the issue. I am waiting for your valuable suggestion. Thanking You
    Rajin M Linus
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by Anders89 on Sun, 09/22/2013 - 21:22.
    Are you using a USB or parallel port interface to the emulator?
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by rajinmlinus on Sun, 09/22/2013 - 21:51.
    I am connecting the emulator through parallel port.
    Rajin M Linus
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by Anders89 on Mon, 09/23/2013 - 20:13.
    What version of CCS are you using? Can you connect with CCS directly?
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by rajinmlinus on Tue, 09/24/2013 - 08:30.
    I am using CCS 3.3. I can connect the CCS directly with traget. No problem in that. When try to interface through VISSIM , the error message in VISSIM is TI driver error 100?. and CCS also showing some error commends. Thank you for your efforts
    Rajin M Linus
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by Anders89 on Tue, 09/24/2013 - 09:13.
    If you also have a newer version of CCS installed, VisSim will try to use it. We have noticed that newer versions of CCS have troubles with the parallel port emulators. You can force VisSim to use CCS 3.3 by editing the file \windows\vissim.ini Search for[F280XDSP] and add the following line :
    useCCSv3=1
    Then restart VisSim
  • Altair Forum User
    Altair Forum User
    edited June 2016
    Submitted by rajinmlinus on Tue, 09/24/2013 - 09:59.
    Thank you for you immediate reply. Can i know what is new version. i am having the CCSv3.3.As you said i have done it as follows windows\Vissim(Configuration settings)[F281xDSP] \ last line of [F281xDSp] added CCSv3=1 After that i restarted the vissim. Then the error is as follows
    Under Vissim/ECD TI Driver Error -100,? Click Ok Then again under Vissim/ECD
    If target has lost power, restart VISSIm. I am in unable to rectify the issue.
    Rajin M Linus
