HyperMesh version 13 model crashed a lot. Once saved and exit, restart HyperMesh and try to reload hm file, it shows 'Error with model file'. Anyone else has this issue? Is it a bug in Version 13?
Do you have latest updates yet? More information about this please.
If it's possible please share also your model HM.
HI,
Please try the below:
Close HyperWorks application(s) and Please delete setting files on your machine. Follow the link below on how to delete setting files:
http://forum.altairh...iles/?hl=delete
Also, delete .Altair folder in temporary directory. Go to Run and type
in %Temp% and click OK.
I tried to delete all these items, not working. This becomes a big issue since you may lose the entire model when it happens. This same problem has already happened to me three time with V13. HYPERMESH NEEDS TO FIX IT QUICK!
HI, Please try the below: Close HyperWorks application(s) and Please delete setting files on your machine. Follow the link below on how to delete setting files: http://forum.altairh...iles/?hl=delete <?xml version="1.0" encoding="UTF-8"?> Also, delete .Altair folder in temporary directory. Go to Run and type in %Temp% and click OK.
Thank you so much for solve this problem for me
