I am calculating the ISAR image of this model using ISAR script but I am having an error 'The combo box does not contain any specific index'. I have uploaded both script and model file.
Hello ben,
Have you worked through the example models distributed with the ISAR script on the Script Exchange on Altair Connect? There are requirements for setting up the CADFEKO model and the model that you included above does not seem to be setup correctly. There is a script included with the above-mentioned to help users setup a model in CADFEKO correctly. The model should be a mono-static RCS calculation (thus, looped plane wave and the far field is calculated in direction of plane wave incidence).
