I have an issue with creating a gerber file from a CADFeko model that I made. The problem seems to rise when there is hollowed out geometry. For instance, my file consists of many many of such geometry:
When I export my model, I get a gerber file which only shows filled up squares. I don't see any of the inner 'rings'. When I do a test with the same dimension but a form like this:
The gerber file shows the appropriate geometry.
I'm wondering if it's an issue with my FEKO model or the way gerber file works.
This is my first time with gerber files and FEKO so I'm sorry if this question is very basic.
Thank you
