Can we change the axis orientation( UCS/WCS axis) (for the geometrical setup rather that changing the geometry by rotate/translate)?
hi Sumit,
The option is available in Incremental analysis drop-down mean > Setup > Systems. You can define your own UCS.
ok thank you
